D Alan Stewart
10 µW
I’m building something custom (it’s not a scooter) and have acquired two E150 front wheel replacements for two of the four wheels. THESE. I’ve decided the easiest way to mount them is to acquire two scooter front forks. Every site I’ve found that advertises E150 front forks says they are out of stock or discontinued. I just need two of a fork that is compatible with these wheels and has a steerer tube. The steerer tube doesn’t need to be compatible with the E150. I’m not even going to steer the vehicle with these wheels, but the steerer tube will be used to allow the wheels to follow the direction of the vehicle. I.e, these will be trailing rear wheels. Each wheel only supports only a quarter of the weight of the single rider, so the load is far less than when used in the original application.
Any suggestion on a source for E150 front forks or for another fork that should work? I can give wheel and axle dimensions.
TIA,
Alan
TIA,
Alan
