titusmc
A friend at work gave me two dead Porter Cable 18V lithium batteries to work on since he knows I have built battery packs for my bike. I had spare high discharge cells (Samsung 20Q, LG HG2), so I decided to try re-celling the packs for him.
Each pack is 5 cells in series with a BMS. For the first pack I replaced the dead cells with HG2's, and the second with 20Q's. All connections for balancing wires are correct, but the packs read about 13V across the main power terminals (instead of 20V). I suspected that the BMS was doing something either because the cells were above 4.1v (I had read that the original cells in these packs were 4.1v - not 4.2v) or because they were out of balance. I tried to connect one of my imax B6's up to the pack to do a balancing, but I made an unknown connection error and magic smoke came out of the B6. Much to my surprise, however, the battery pack started putting out 20v again across the terminals, so I gave it back to my friend and it works in his drill.
I still have the second battery, and it still outputs only 13v. I don't want to blow up my only remaining B6, so I'm not sure what I should do. I'm wondering if I can hookup my imax b6 main leads to the pins on the battery to emulate the stock charger and get the BMS to do whatever it needs to do.
Anyone have a similar experience with re-celling drill batteries? Or just useful advice?
