Alan B
I started a print on the forward part that has the locking end of the MTX trunk adapter. My plan is to stop it at about 25% and use it to test fit, everything critical is within that section. The full print is over 6 hours even in 0.30mm layer draft mode, no reason to use that much time and material to check things when there are likely some issues to resolve. Then I can make any adjustments needed and perhaps be ready to make one for real. I'm leaving the bolts as-is for now.
OK, the print took about 3 hours to get to a useful level for testing, I was tempted to let it complete but it wasn't a good color so I stopped it. Have tested the M5x70mm capscew, washer, tee nut and MTX bag. I did make a minor adjustment on the countersink depth which is not critical, but easy to improve. I also deepened the cuts that allow it to flex and clamp. The one thing I have not done is dig into where the bike is stored and check the tail fit and clamping action. Perhaps tomorrow. Tis looking good so far.
