Couple general questions for all:
1) What is the basic recommended charging speed for, say, Samsung 18650 3ah cells? If they were in a 4p config at 12ah, could one safely charge them with a 3a charger? Is .5C or 1C a standard for best practices charging for decent cycle life? How far could one push it and not see excessive wear, 2c or?
2) Any idea when using regen braking on an e-bike or escooter how much is the general practice for charge through regen, .5C or 1C like wall charging or?...
3) Generally, if one uses regen braking and they fully top off or fully charge their pack and then, say, were to ride down a hill and use the regen braking right away, would the controller and/or bms limit the pack from being overcharged and simply 'shut off' any regen (I've heard from a boosted board eboard user that he experienced this after charging fully and riding down a hill to discover it has no regen power - unlucky for him since there is no mechanical brake or skid ability according to him, but he was able to control it luckily) and thus one would have to rely on a mechanical brake, or could it cause an overcharge fire like we've seen with the hoverboard fiasco in recent months? Just curious others experience with this in general if they have a gearless direct drive motor that uses regen braking to help slow down their e-vehicle without the need for overuse of a mechanical brake
4) For high discharge batteries, like the Samsung 25r or 30a etc that claim 15a or 20a discharge rates, what is best practice or generally accepted continuous amperage and or peak and for how long should one sustain the peak? For example, when e-biking I generally pull about 30a (my max setting on my programmable controller) red-lining it on large hills for maybe a few minutes max and then it levels out on flats or going downhill and rarely needs more than 10-15a to get up to full speed on the flats. I generally try to stay around 2c so on a 15ah pack I try to keep it maxed at 30a for a few minutes at a time mostly and then for most street riding I use about 1c or 15a in general. Any recommendations here? I'd of course like to use the smallest, lightest, cheapest batt pack I can get away with but of course want to use it for the long term and not overdo it or burn them out prematurely. I rarely go above 2c on my packs and again only for hill riding mostly.
5) Lastly, what is considered the standard for 24v, 36v and 48v packs? I have seen 7s for 24v, 10s for 36v but for 48v I've seen anywhere from 12s, 13s to 14s...Any standards here or are they all "correct"?
Thx for your comments!
