Hi all,
My setup consists 14S2P Multistar Lipo 16ah giving me 51.8V 32AH nominal. My controller's maximum current is 40A and at this level there's normally a voltage sag of around 3V. Today I noticed while going up a long hill that the voltage sag was much worse than usual and that the cells were not recovering as quickly as before.
When I got home I checked the pack and it was very hot. Two cells out of one parallel string were completely dead (ERR on voltage checker, I'm assuming 0V). The other string is completely fine, balanced perfectly. Buy my commute is over 20 miles and 14S1P 16AH (1 year old) probably isn't going to cut it. I suppose the cells have lasted well, they have over 370 cycles on them.
I need to look at options for a replacement battery pack, something that will last longer than my old pack, ideally in a safer package, and something that will put up with 40A burst when I need it. My bike is literally a car replacement for me - I use it all year round in ANY weather (and I'm from Wales, UK so that normally means RAIN!) and cover 40 miles a day. So lots of cycles is important - I charge at home and at work.
Has anyone come across these before? I've searched the forum but can't find any info about them. I could build a LifePO4 16S 20AH pack for around £320 (£0.31 per WH) compared with a Multistar Lipo 14S20AH pack for £275 (£0.26 per WH), but the LifePO4 chemistry should allow more cycles, should it not?
https://www.ev-power.eu/LiFePO4-small-cells/LiFePO4-High-Power-Cell-3-2V-20Ah-Alu-case-CE.html
Thanks
Jon
Thanks
Jon
