megacycle
I was looking at getting a higher voltage controller running about 132V and looking at precharge setups and battery power out protection like fuses and being, primarily, electrical background and not so much electronics, i came up with a set up i hope can be a major improvement on the non standard kinda adhoc set ups for high energy and voltage set ups capable of delivering major KF.
Most precharge arrangements, for low energy bikes, like <100V and <100A, use an arrangement with two leads, one large fused main lead and smaller precharge lead with an in-line power resistor and with or without a switch.
Most are then covered in heatshrink sleeving and tape to stop them shorting out during and after prechage.
I was thinking for my higher voltage/amps setup this might expose me to worse cases of KF than this
and more chance of shock in the wet and fires from shorted controllers and incorrect fuse types.
There's quite a few guys using circuit breakers and i had a few solar polarised ones lying around, just hanging for an app like this.
Theres quite a lot available, now domestic solar install has made them common place.
They can be had for sub $10 US, this can be cheaper than an equivalent fuse at 80V+ ratings.
The circuit breaker has about 2 minus points and about 10 plus points for it in comparison to the equivalent fuse.
One of those plus points no often promoted is it is capable of being coupled to ancillary devices to control it.
One of these devices is called a shunt trip release, which could be got for around $10 and basically can make the mcb trip off remotely, like a contactor,except you have to turn the breaker on again.
This can enable the mcb to act with a precharge scheme and also possibly protecting a controller and its wiring from further short circuit damage, as the main power is then interlocked off.
