theRealFury
mlt34 said:Thanks, I have one (hopefully) more question for you guys. After posting last time, I checked the cell voltages individually both by measuring from B- to each sense wire and subtracting each consecutive cell, and then by measuring from one sense wire to the next to test the cell voltages. All the cells were exactly identical. I then ran the bike while it was up in the stand for about 2.5 AH (the battery is 15AH) and now I checked the cells again (the morning after the 2.5AH drain) and the cells are still identical, they are all 3.334 V. This seems weird since they used to be so unbalanced, and all I did after soldering on the new BMS was to solder on a new wire to the B- pad as an extension of ground to help me measure the cells when it's all wrapped up, and I put it on the charger for about 2 minutes until it started doing the odd on/off thing from my last post. Are the cells really all exactly balanced, or am I measuring it wrong?
I would say your measuring it wrong but im not following 100% how you were measuring them. The chance of every cell being balanced to 1000th of a volt even on a brand new and fully balanced battery is practically impossible. i would check your readings again. My guess is that somehow you were always reading the voltage from 1 particular cell. Personally i would have balanced the cells up (either by using a 5v phone charger on the 3 lower ones or by bleeding the higher cells to reduce voltage) before i hooked up the BMS. then you could have just topped the carge off as per normal to test the BMS is working properly.
