max_m
I'm hoping some of you know a bit about appliance batteries. My Samsung robot vacuum sat in a shed for a few weeks, including during a cold snap. When I brought it inside, it wouldn't turn on, and wouldn't charge from the docking station
Some observations. The cells have some charge (>3V) and are balanced, and I can charge them directly (bypassing the BMS).
Voltage on the main output pins on the BMS (P+, P-) is much lower than the battery pack, and doesn't accept charge. There are two additional pins: PD1, PD2. They appear to be pulled to ground. No idea what they do.
I assume the BMS has entered some sort of protective mode. I disconnected the cells briefly from the BMS to try to reset it, and that brought the BMS output voltage up, but as soon as I tried to use it in the vacuum, it shut down again.
Any ideas?
Any ideas?
