I want to build a velomobile for long trips.
Currently, I have 7s 80Ah 'main' battery and after a bit of a fiasco with a 200kv motor I'm contemplating a 130kv motor - but to reach desired RPM more voltage will be required.
I contemplate getting an extra 3s ~90Ah auxiliary battery.
Each will have it's own BMS.
First battery will be used as a motor battery.
Second will be wired in series with the first AND will have a separate 12v output for things like lights, cooling fan, etc.
Batteries will be charged separately.
Otherwise using a voltage booster is possible, but at a hit to efficiency which I don't like.
I'm new to this, but it sounds doable to me... or is it?
