Adrianv544
- Joined
- Mar 13, 2020
- Messages
- 1
Hi all,
I've searched all over the internet to find an answer to this but cannot seem to. Preferably something I can confirm prior to attempting. Apologies if this is hidden somewhere in one of the many sevcon threads, I've spent so much time reading them I wouldn't be surprised if the answer went right over my head.
Any input from someone familiar with sevcons gen 4 controllers would be greatly appreciated.
Essentially I am trying to determine if I can map sevcon functions like FS1 / Deadman / drive profiles to a message broadcast over the CANbus rather than a digital input. Reason being is that we have a second controller for controlling the low voltage items such as indicators / lights / button inputs etc, but cannot pull the ~70V open pin voltage of the sevcon inputs with this controller without using relays. This is something I would like to avoid if possible.
I understand that the CANbus / PDO system can be used make the sevcon broadcast things like RPM etc over the CANbus, but I cannot, from what reading material I've managed to find, confirm with complete confidence that you can also configure inputs the same way. I am ~75% confident that I can, but cannot power on the sevcon and experiment until wiring is finished so was hoping I could determine the answer prior to that point so I can prepare by buying additional relays if I can.
Apologies for the wall of text and again, any input from anyone is much appreciated.
Thank you!!!
Thank you!!!
