Allex
No worries Sam, 20s or even 22s is not problem to load in.
Kepler said:Kepler Beta update:
Visited JK last week to discuss what I wanted to do with a Beta. As a personal favor he has agreed to modify the stock swingarm by adding an extra 25mm to its total length. So I am now committed to a full 29er Beta. 8) I am hoping it gives it even more of a bike look then the stock Beta. If it looks weird and rides poorly, I will just pay to have the swingarm cut back to stock.
Tipping back towards a geared hub on high voltage. My Fighter setup has very few negatives so I am leaning towards sticking with a tried and proven setup. I run a Bafang Code 12 in my Fighter at the moment on 18S LiPo. Good for 55Kph. I am leaning towards a code 13 or similar and run it on 21S4P 25R 18650. It would be 3 separate 7S packs connected in series.
Kind of going down the LiPo pack arrangement so I can use a stock RC balance charger when needed rather than a BMS. My experience with 25R 18650 cells is that they hold amazing balance anyway so a periodic balance charge should be all they need. Running 3 separate 7S packs should allow me to squeeze the 3 packs in length wise. At least that is the plan.
Will stick with an internally mounted Infineon based Mini Monster 6FET. Good for 100V and 40A. At 84V, I will keep the peak amps to around 30A which will be a walk in the park for this controller. Will also add motor temp protection to the motor this time round. Would be nice to go down the Adaptto path but I am struggling to justify the cost compared to what the Mini Monster and CA3 combo still offers. Other differentiator will be a Thun Bottom bracket for true torque sensing PAS.
Aesthetics wise I have paid some extra cash for matt black finish. Will do something similar to Alex to expose the frame latis work with carbon fibre behind it. Suspension will be Hyena Spec back and front. Have be testing those DNM 6 forks and they are very nice indeed.
Anyway, the wheels are in motion and excited to have another project on the go.
Swe said:Anyone else had problem install a bottom bracket? I cant insert my Hollowtech II by hand (with only fingers), it gets stuck after 1/4 turn. Tried to clean it, but maybe not so good before my first attemt.
Or did you use more force? Have read you should not do that, or is it just on aluminum frame?
Guess I have to get it to my LBS...
Tats said:Saw my 1st Stealth in the flesh today at Karrinyup road - what a magnificent looking piece of kit! Looked great in black with the twin headlight option. starts saving pennies.....
Next time you run into that guy, tell him to get on es and post up a vid here. I want to see this Karrinyup riding area.__mike said:Tats said:Saw my 1st Stealth in the flesh today at Karrinyup road - what a magnificent looking piece of kit! Looked great in black with the twin headlight option. starts saving pennies.....
Not everyone would know where Karrinyup road is but its at my door step
Most Sunday mornings along Cottesloe (though haven't ventured that way in a few months) when I'm on the racer there's a guy that rides his black bomber up n down the strip, he'll always pull off some nice long wheelies when you ask him too
The stealths are sold around the corner from me at action sports in Balcatta
Mike
Might go for a ride today down at this Karrinyup area.Rix said:Next time you run into that guy, tell him to get on es and post up a vid here. I want to see this Karrinyup riding area.__mike said:Tats said:Saw my 1st Stealth in the flesh today at Karrinyup road - what a magnificent looking piece of kit! Looked great in black with the twin headlight option. starts saving pennies.....
Mike
Mammalian04 said:On a sadder note, the steering tube split when we were setting the star nut. It seemed weak when we cut the tube down and the pipe cutter only made it less than halfway through the tube wall before the rest just cracked off. It seems it was very brittle and maybe that should've given us warning signs. When setting the star nut, the tube cracked several inches down the tube.
Mammalian04 said:Mammalian04 said:On a sadder note, the steering tube split when we were setting the star nut. It seemed weak when we cut the tube down and the pipe cutter only made it less than halfway through the tube wall before the rest just cracked off. It seems it was very brittle and maybe that should've given us warning signs. When setting the star nut, the tube cracked several inches down the tube.
So Ting at DNM has got me squared away with new USD-6 forks coming. I just shipped the ones with the broken stem out (back to Taiwan) and the new forks should ship out soon. It took a little time but they have been quite helpful. Good on DNM in managing the exchange. Lets just hope the new one doesn't crack!
one4torque said:Mam i have a goid dnm here for beta if you are chompin to get started. You can send me the other when arrives. Im moving houses so will not be building beta for a while.
Hyena said:Glad to hear they sorted it for you. There's no arguing that's a QC issue. Somewhat random, I've never heard of that happening before, and I've roughly smashed many a star nut into steerers. It has made me rethink my brute force methods though!
