Surron magura throttle issue
Alep
Miami
So I recently had a problem with my surron and I chopped up the wiring for the magura throttle on the frame. No problem put it back together, without realizing I cut off the resistor on the blue wire of the throttle. It runs perfect but turns off at full throttle, I’m assuming that’s because of it lacking a resistor for WOT or top end. Would like to know what resistor I should order as I’ve searched everywhere online for it and can’t find anything about it anywhere. Thanks.
What's the remaining resistance of the throttle at the point of turn-off? Meaning, if you turn it to that point, and mark it physically, then disconnect the throttle and measure resistance from it's signal wire to it's power wire, what value do you get?
You can use that value in a formula with the total resistance value to figure out what you'll need to use between the power wire and the throttle. I'm not friends with math so I can't tell you how to make the formula, but it should be "simple" algebra. :/
