"really good" also means "out of our price range" especially for multiples. :lol:
I'd've stuck the 40A Grin 12FET (that I actually bought new after the fire) on there if it weren't for the super-annoying surge/rollback throttle issue (thread under that title somewhere about it) that I've never resolved. It's still basically the backup controller/front motor on CB2 for that reason.
I'm hoping ot have some time tomorrow or Monday to fix one of the 18FETs.
Or to at least play with this one some more and figure it out. I've been reading thru that thread about it and there is info, just have to dig it out of all the side discussion....
I played with it a little more today. Nothing engages a regen mode in the wires that are already out there.
First was with an actual 3-speed on-off-on switch hooked to the red 3pin connector, center wire common, and it does indeed do something on one setting--shorting (yellow) to ground forces it into a low-speed/power mode. Haven't tested it on-road yet to see what the max it does would be on that mode. The center-off mode is same as no switch. 3rd position shows no apparent change off-ground, will have to see if it makes a difference on-road.
That green-plug/brown wire turns out to be an analog-output voltage for "speed". Ranging from 0v to about 28V, I think it is coming off a phase; I didn't scope it but the DMM picks up a frequency at less than full throttle of a little more than a dozen khz or more (pwm of the motor), and once ft is reached it changes to about 300-330hz (flickers) which sounds right for the rpm of the wheel (or block commutation?). I'm not sure what possible use this would have to be pinned out to the outside world, unless there are analog speedos that are powered by this sort of thing on Chinese scooters. I have an old boat speedo that's electrically powered, so maybe if I can find that I can test the theory if it's the right voltage range.
The white single wire doesn't seem to do anything. It's 0V by itself, and either groudning or 5V to it doesn't make any apparent change to the behavior.
The yellow single wire has gone missing? I have no idea what could have happened to it but it isn't in the bundles anymore. :? I looked around the areas of the house where I worked on the trike and/or the controller before putting it on there, and didn't find it, nor sticking out of Yogi's poop in the yard. I can't imagine it would have fallen off while riding; I'd fixed the diode solder joint to the PCB, so unless the wire itself wasnt' soldered to the diode inside it's heatshrink, and vibration let it finally work out of hte silicone gasket/holes in teh controller end (whcih sticks up, not down), it ougth to still be there. So to see what that is I'll have to open up the controller again.
And that's the total of all the wires already on it. Have to open it to check anything else's functions, adding more jumpers or wires to the outside.
