No problems with the above until yesterday morning on the way to work, where about halfway there, the left motor (taht I just redid the wiring on) suddenly began acting as a brake instead of a motor. A quick stop and roadside check found no mechanical issues, and unplugging the controller form the motor didnt' fix it, so the problem was inside the motor or wiring. No time to fix it then, so had to wait till I got home last night, in the rain.
The main problem with riding it that way was that it took about twice as much power as normal just to cruise, and accelerating was realy really difficult, taking around 1/4 mile to reach 20MPH. So I generallly couldn't even get to 20MPH before having to stop again. THe wierd part was that the problem decreases significantly around the 10MPH mark.
Wierdly, I also found that the right wheel on the grinfineon isn't producing any noticeable regen braking when the lever is used, though the controller LED indicates it *is* braking. Was problematic on the wet roads with only a front mechanical brake. :/
Tilted trike over on side in the shed (to be out of the rain) once home, then took wheel off and cover off and found one phase wire coil-to-external-wire connection point was rubbing against hte motor cover, arcing to it part of the time, and causing the problem. There was also a single strand of between-coil wire in a different area that had become welded from arcing to the stator support ring. That broke when trying to fix that, so had to solder it together and heatshrink it. The main problem was easy to fix by reinsulating ti and bending it down into the support well and tying ti down better.
Reassembled and the rpoblem appears to now be gone, and the controller still works. We'll see how it continues to work on my commute today.
Is also expected to be raining a lot for the next few days.
