SpeedEBikes
A hall sensor got zapped in a Crystalyte 407/409. Not knowing how to unpot and replace the sensor, and just happening to have a second rotor on hand I swapped the rotor.
The motor runs but not smoothly and it's drawing far too much current without a load. I just recently bought an oscilloscope so I hooked it up to see if I could see anything obvious amiss. I've attached a screenshot of the scope showing the hall sensors on the digital logic inputs at the top of the screen and the voltages across the first two phase wires (yellow and green). I took a second shot capturing the green and blue phase wires and it looks very similar.
This is with an old Crystalyte analog 20 amp controller being run on a battery at 50 volts.
Does this trace suggest a problem? I'm wondering whether it is typical for the active phase's signal to diminish this much when the successive phase kicks in? Also, there is the spike while one phase is off and the successive phase cuts off. Any suggestions for further troubleshooting?
