Diameter at the outer magnet face is 288mm. If you do a circular array of 68 10mm x 4mm, at that diameter, you'll see the space available. Internal diameter of the rotor was 272mm.speedmd said:I have not had a chance to draw up what you last simulated for rotor core profile shape. Would like to take a stab at it with modifications to possibly dove tail into a custom magnet shape. If you have some updated core dimensions you would recommend, I will try to give it a go when time allows to see what core material is left to use in this tight spot.
