Last year I made a 15s5p battery pack of sanyo ncr18650ga. Currently sitting at 110 cycles. I want to expand the pack (15s8p) without having another BMS (My current BMS is the Aliexpress Bluetooth bms, 15s, 60a). I would add another 3 ncr18650ga in parallel to each series branch.
I know this isn't ideal but I don't see this being a safety issue. The new batteries will end up discharging a bit into the old ones on the same branch but the BMS monitors each series branch.
From searching it seems as long as I add them in parallel everything should be fine. In series can get you in trouble.
Thoughts?
Thanks
Thoughts?
Thanks
