zacksc
I have 3 LIGO batteries from Grin that I haven't been using very much recently. In series, as you all know, they make a nominal 110 volt dc source. I would like to ask if I can use that as the power source for a 24 volt converter which normally plugs into a 110 AC wall outlet? I already have an Anderson to 110 volt adapter, so it would be pretty easy. But I am not sure if it will damage my converter. Usually the converter input is 100 to 240 VAC (55 HZ), and it outputs 24 V DC. (It is used to charge a Jackery 1000.) I enclose a picture of the converter here. Does this seem safe? Will it damage the converter?
