Montiey
- Joined
- Dec 10, 2015
- Messages
- 89
I was successful in updating the firmware, and everything works great (including manual braking from BLDC tool). When I try to detect the motor parameters, I get some finicky behavior and then a fault.
From a bit of searching it seems like the common cause is a busted DRV8302, though I don't know how the braking still works. I got a couple ABS Overcorrect errors, but then I removed the pulley/drive wheel and then BLDC started just showing DRV8302s.
Here is a video:
https://www.youtube.com/watch?v=DP7jcdVfY18
I probably broke something when I reversed the input at first (momentary, just sparked). Luckily, I had sense enough to just use a single 4s 5200 LiPo.
Here is a video:
