Mark_A_W said:
Crikey. At 60v nominal and 30amps, I do 15Wh per kilometer. I only get 9Ah out of my 10Ah pack. I wouldn't drain yours that low if you can avoid it. The pulsing is not a BMS thing. BMS's only turn off. They don't modulate the current. It's your CA or Controller.
I'd disconnect the CA for the next run - do it using a odometer. See if it misbehaves. And 7 or 8A is a LOT to charge with. My charger is 3A. If your powersupply comes back to life, stick to 3A. Do you want my old Li-ion charger? 42.2v, with lithium profile. It won't get you fully charged, but it will get you running.
I went the full hog because I wanted to see that the LVC actually worked. When it cut out the bike lost power completly. But if I disconnected it and reconnected it it would start up again for a few secs. I burned off the last 2Ah close to home waiting for it to happen. I'm happy to see that it does work.
I only need about 25km range to get to work and back and I woulden't be using battery energy as fast as I was using it today. I pedaled very little just to try to run the pack down.
I'll have to try it without the CA, good idea. The CA is what limits the current though, so I'll have to be careful not to push it too hard. I'll have my 30A inline fuse anyways but it will be a PITA if it pops. I thought it was strange that it diden't start 'pulsing' till 7-8Ah in, it didn't do it at all before then. I might ask justin at ebike.ca, maybe its something in the CA or controller that only crops up as a result of some thermal issue...
Both my headway pack chargers are now dead. If you'd send that lithium charger to me that would be awesome, I don't want to leave both these packs at such a low state of charge for too long. I don't know how long it will be before my 36v4A charger from rechargablelithiumpower arrive either.
The LED on my powersupply wont light up, and the DC voltage output is like 0.03V when plugged in. I don't know what's going on, I opened it up and there is a fuse but it's not blown.
The powersupply doesn't have adjustable current, you set the voltage and that's it. Maybe the battery pack tried to pull more then the 8A the PS is rated for and that was what killed it. Not sure, I should have fused the DC side with a 7-8A fuse.
