voicecoils
Updates:
Motor's in a wheel, a 36h Rhyno Lite Pinned wheel. I'm using 216mm spokes with a 1 cross lace, but they are a tad long. I would suggest anyone else with the same hubmotor & rim combo go for 214mm as suggested by johnrobbinholmes. I've put some zefal cloth rimtape on and hope it will be all good. I'll also have the wheel trued up at a bike shop even though it's reasonably true and tight already.
I've mounted my Cycle Analyst to the handle bars, but have 2 concerns: The mount seems a bit flimsy and I'm not convinced it's waterproof. Two things to look into.
My 20 mhz crystal resonators came from farnell.com and I soldered one on with no problems. the 72v 28A ecrazyman controller is now happily blinking faster. I've done fetcher's LVC mod by putting a 24k ohm resistor across R3. The LVC now trips at 47-48v which would mean 2.0v cell voltage for my 72v pack. Tripping the LVC at 2.1 per cell would probably be a bit safer.
I also bought a bunch of 45a powerpole connectors in the same farnell order and will be using them to connect the stand alone Cycle Analyst in line with the controller and batteries and for a bunch of other connections. They're smaller then I expected! I might use them for the phase sensors too In general, I think the quality of the connectors on the ecrazyman is pretty low. I hope to change most of them to more reliable and watertight connections.
pics soon 8)
pics soon 8)
