smotors
Something goes wrong with me. When I press the remote control, the motor can rotate the slider on the screen. When you press the calibration, on the third screen for some reason there is no additional window. There is only a temperature window. And when you go to this third screen, the motor stops. Am I doing something wrong, or my software does not allow me to do the synchronization calibrator?
...added
when I rotate the engine with the slider on the screen, then move all the way to the right, the motor runs stably up to maximum rpm of 4400, but when I switch to control from the throttle stick, it starts to crash at 4300 ...
...added
wow, I saw the right menu)
when the switch is at low speed and maximum speed, I see such a number (shown in the picture)
what should I do next? adjust the parameters so that it is in the range of 100-200? and where to save the result?
https://youtu.be/HEzUUuL9BTA
...added
...added
