Nice they look the same bud only the bolt connections look al litlle longer....i think they are the same bud because of de pvc cover for
the parallel en serie+bms conections for VW module they make the -/+ pins on top of the cell,s flat so the cover can go flat on top of the 12 cells in the module.
Sanyo/panasonic.
how mennie cells do you have in parallel to pul out 30C
if you pul this out of a singel cel this wil be extreem for a non lipo bud li-ion NMC cell!
Have you shake the cells en listen with aure ear?....sounds like there is some liquit inside,maby for cooling based with water and salt??
