daddz
i have decided to go ahead and water cool one of my headline motors with copper coated steel tube used by a local hydraulic shop. i want to see what others think of the idea? question first
is the copper coated steel tubing going to affect the magnets?
is it worth finding and getting some copper tube shipped in at about twice the cost?
i have several choices of tube size from about 8mm od down to 4mm od, im going with the smaller size i think to have more contact area, small as it be.
the plan is to coil the tube around the motor starting about 15mm from the end of the casing and going right up to where the motor changes shape, with both ends of the tube extending between 8cm and 15cm behind the motor all depends on which part of the frame i mount the tank on.
which would be better?, a loosely wrapped coil around the motor with gaps between each wrap/twist? or a tightly wrapped coil with no gaps between each loop?
whichever is used im planning to use some sort of silastic or computer heat sink paste in the middle part of the coils, so there are no air spaces and for better heat transfer with a 2 part metal bonding agent at the ends to keep it all in place.
i have several options to use as water tanks, or if i can find it a small old gearbox cooler but i doubt the air flow would be enough to be worth using it at the speeds i ride.
water flow i have a fish tank pump that runs on 24v its pretty small and should do the job ok even at the slower flow rate due to the lower voltage, or i will get one of these http://www.buyincoins.com/item/34689.html
the water tank will be mounted behind the motor, at this stage im thinking of using a metal flask or one of those metal drink bottles that hold about 750mls of water, or even an empty aerosol can, i have a few options and ideas for that like an old sla battery with the insides removed.
camera has been fixed so here's a pic of the motor its going on.
