monette999 said:
What are the batteries that could be affordable 18650 or 32700 or Lifepo4 cell.
What does "affordable" mean to you? Meaning, what is your exact budget?
How much space do you have for the battery, and it's actual dimensions?
How much weight can you allow for the battery?
What are the exact specifications you need your battery to be capable of? You need to know what the battery has to do before you can make a battery to do it. Meaning:
--what is the average voltage your battery must maintain during the entire runtime?
(is it a "48v" controller? Or a 72v? Or a 5v? or a 1v? etc)
--what is the maximum voltage your controller and the rest of the system is capable of?
(will it explode if you connect it to a 6v battery, or does it take 124v to destroy it, or does it run fine as long as it's less than 84v, etc?)
--what is the kV of your motor, meaning how many RPM does it spin for each volt you give it? And how fast do you need it to spin, to do what you want?
--what is the average current it must output during the entire runtime?
(when running the kart around a track, does it typically take 40A, or 2647A, or half an amp, or etc?)
--what is the maximum current it will ever have to output during the entire runtime?
(when starting the kart from a stop at full throttle, or climbing a steep hill, does it take 80A, or 9275A, or a quarter of an amp, etc?)
--what is the maximum runtime you need, at what power level?
(do you need the kart to drive for 4 minutes at 1743watts, or 75 hours at 10 watts, etc?)
