Can you tell me something I have not absorbed that you have told me please?
You've not absorbed
#3.
Let me know which questions I have repeated where someone gave me the full well written answer already.
I've listed one below and there are others.
OP:
I get a bit confused when everything is diagonal
Me, I enjoy watching cycling, but even in a senior race I'd put myself and others at risk. We all have limitations, I can see it can be risky and that I don't have the aptitude. You've wisely recognised that some things are confusing and you can be unlucky: while someone else does your battery you can be building a great bike.
===0===
#1 OP: Where do you put the battery when you are building it? Maybe an oven tray or something like that? So if a fire starts it is easy to carry it outside
#4 Build outside... I have a portable table I put outside the garage in the driveway.
#7 OP: perhaps a glass oven tray if I make it inside?
#8 if you screw up and things start getting hot at that point you might not have time to put [gloves] on.
#10 as soon as you stop pouring water it reflashes but eventually the fire goes out. The fire is like a blow torch in intensity.
#11 Even if you had... a respirator to protect yourself from the fumes... I just wouldn't build a pack in those circumstances
#15 OP: It is not far to go outside... maybe do it outside
#18 me: count the posts above that mention mishaps and check you're happy to "just lift it outside" (meant rhetorically)
#20 OP: What about sitting close to the outer door?
(... 16 posts later ...)
#36 OP: But you don't recommend garage then?... where else could I build it?
