so little update on this subject...
npc is the holy grail of 18650 tab welding. iv decided to pursue the loose goose.
It seems diy nickel plating copper is actually pretty straight forward.
http://www.instructables.com/id/High-Quality-Copper-Plating/
here are some tests with 0.16mm copper foil in nickel acetate solution-
all fine and good
also cheap.
the next problem is copper has very low resistivity. this means that a relatively large amount of power is required to make the weld, when compared to something like nickel.
also, it means the path of least resistance is through one electrode, across the copper strip and back up the other electrode(not through the battery terminal under the copper tab)
this can be improved by making a small slit between where the electrodes go.
it seems the best electrodes for welding copper are tungsten or molybdenum tipped. this is due to these metals having very high melting point and having slightly higher resistivity, so the current causes heat in the electrode tip that makes the weld.
some electrodes from japan im looking at right now-
https://mail.google.com/mail/u/0/?ui=2&ik=f81c378e89&view=att&th=14fd3b3ae901ab9c&attid=0.1&disp=safe&zw
I have been able to weld the npc i made to 18650 but the successful weld was not very repeatable , and due to the high current required, if something goes a little wrong- not enough pressure or surface not clean enough, you getan allmighty ark that blows a hole clean through the can
so hopefully, using a copper electrode with a moly or tungsten tip, and something like riba's jp welder, i should have some success.
more updates soon, any feedback info on this subject much appreciated
