jatgm1
Long story short I'm trying to get a mi365 scooter and add another battery pack to give it as much range as possible. I'm looking at the 12.8 ah version and want to get a battery that is as identical as possible with a built in bms, to get the best range possible and keep it safe. Any suggestions? reliability is important too Also if you know of a mi365 with more power and a battery identical to that? Basically looking for a small scooter I can get cheap that's really reliable that I can add another battery to, and also have a backup In case one shits the bed to use until I get a replacement, so being the same size is important too. Also that I can flash the firmware on. Also I was hoping to get a second motor hub that works for the rear too and a switch to disable it, but not sure if I can get that to work, so not that important. (Idk if I can cram all the electronics in there)
