Hey guys, quick question. A main drawback to direct drive motors is that when the battery dies, you then have to pedal against the regenerative resistance of the motor (turning the motor into a generator and charging the battery, which makes hard work for pedaling). Could you not just disconnect the motor leads from the battery (making the motor an open circuit) and then pedal normally? If the motor is an open circuit, it shouldn't generate any "regenerative current" because there is nowhere for the current to go. However, if this was true, I feel like every direct drive motor would have an option to toggle battery connection from the motor. Please let me know where I've gone wrong. Thanks!
