I know the BBS02 is rated for 25 amps, but is that the absolute max? It won't ever trip the overcurrent protection on a Daly 30amp BMS right?
Also I really don't want to go to a bigger bms, because the battery I am attaching it to is a 15ah Panasonic 3350mah build. Those cells are rated for max 2c discharge rate, which would be 30amps. Don't want to push things.
Mathematically it should all work, but I've been surprised in the past by controllers drawing a lot more peak current then their peak current rating.
