MadRhino
A motor will run when you feed it other voltage and power that it is sold for, but this motor will not survive very high power and abuse.
The controller you linked to can be programmed, but it might not have the programming connector installed. You have to contact the seller to add this option and order the interface wire. A 24 fet is too much for this motor, that can be pushed to its limit with a much smaller controller. Those who are building high power with a mid drive are using much better/bigger motors. You should read building threads.
