Geneticallymodified
- Joined
- Aug 3, 2019
- Messages
- 16
Hi folks as the title says I am planning to wire batteries through my scooter using an additional DC toggle between the Y connector to form 2 "hardwired" batteries and 1 external plug which I can use as an auxiliary power with addition packs
Question is; for a 36v system will these be up to the task
Taiss/2Pcs Waterproof 16A 250V 20A 125V AC 6 Pins 3 Position ON/Off/ON DPST Rocker Toggle Switch Boat Or Car Black KCD4-203N-BK https://www.amazon.co.uk/dp/B07V35LB7M/ref=cm_sw_r_cp_apa_i_1XcSDbS4WBFJF
And also, would it be better to wire the toggle in between the power supply plug on the board (does the board need a constant power flow to keep all the data) and any power source? Or does the board need a semi constant feed so switching packs will need re thinking? Or is there a better way about it?
I should mention this is for a xiaomi m365 I guess [emoji2369]
Thanks for your time
Sent from my SM-G950F using Tapatalk
