BiGH
okay so i've got 1-2 suspect cells in my yesa pack. Before sam will state that tehy are warrantable, he wants me to "modulate" them, in essence balancing the pack.
his reply was this:
I thought it quite interesting to get the non bad cells to discharge down to the same level as the unhealthy cell and then charge the pack up.
I also noted that he suggests using a 3.9v 2a current to charge. I looked at the voltphreaks single cell charger and it says its for a 3.2v cell.... not sure what the go is here.
I need some help guys!. I was gonna pop down to the store and grab a 22? 5w resister and a breadboard to discharge the other cells, should i just grab a voltphreaks charger insted?
his reply was this:
"Charge the battery fully, then check the cell voltage with the other cells,
if the cell have too high voltage, use about 22?/5W resistance to discharge the
high voltage cell till similar to others . If the voltage is too low, you can use constant
power and modulate the voltage to 3.9V and 2A current to charge. Use the method to
modulate the cell to have the similar voltage with the other cells."
