motomech said:
BILLYMC said:
Hi, I need some help? I've assembled a 48v Ebike and am running it off 3 parallel fuse protected 2 series connected 6s lipo packs.= 44.2v 15ah. at the moment I'm charging via 2 separate 6s lipo chargers (4 long cables from the battery compartment-not ideal). I want to find a bms that will charge 12s lipo but am struggling. Some bms i've come across say lion/lipo but as the voltages are different how does it correctly charge/monitor? I would like 30A continuous with a little headroom. The bike itself goes well its just I would like a much simpler charging arrangement. thx in advance
I don't think you need a BMS, what you need is a 12S charger. Like this one;
http://www.hobbypartz.com/75p-1220-charger.html
You won't have to dis-connect your harness to charge.`
It's an alternative, but so is buying new cells every ride, instead of charging your old ones. Which often happens when you buy modeling chargers for ev use. It's more work and more money for less protection from an untidy solution.
I like to see people come here from a modelling background and slowly move towards the stuff ev's are made of. Once somebody knows how ev's work, it seems very backwards advice to tell them how modellers do it. It is almost irrelevant. There is no advantage. It is how all the fires start. There is just nothing to weigh up.
The OP knows how battery packs are made. Wanting that, rather than a pile of cells, gets my seal of approval, and that of every ev manufacturer.
There is a small number of people here who can't actually use a bms, so use modelling stuff. The same minority have 95% of the fires. Lets extinguish as many of them as we can. Lets start making consumer grade packs like the professionals do. They use the safest easiest solution for the end user. Made in such volumes it is cheaper than the less effective alternatives that only modellers want.
ES is the go-to place for ev builders globally. I for one don't want to publish irrelevant charging info that burns another house down. If I'm asked directly about model chargers, I will point someone to a modelling site. It certainly has no place on a bms thread. It's devolution to an endangered state. Darwin jumps to mind.
