A godzillion thanks for passing on all the valuable info on this fechter!
I imagine I'll have to build a rotor with steel over aluminum to avoid shunting (like I understand what shunting really is, tee hee), and use some kickass neo magnet bars or somesuch... similar to dogman's WE BD36 rotor...
I'd have to mechanically secure the magnets (as opposed to gluing) because unlike a hub motor it's the rotor spinning the magnets outward at high RPMs and not the stator.
Fabbing a rotor is very doable since I live in an area with many small mom 'n' pop machine shops so I can have simple lathe work done! When I say small, I'm talking machine shops in their homes.
I'm very excited by this as I plan to work a small alternator/motor into one of the *Sanyo Gear Box hubs, instead of an RC motor.
Other thoughts...
I had a dream last night (true story) that I was using my Journey Kit Controller on an alternator/motor installed on a 26" bike. In the dream, my logic was that the PAS mode is nothing more than a sensorless mode. This was why I was getting WOT in PAS mode. Is there truth in this? Did I just have a premonition ??
I'll have to test it by unplugging the hall sensor wires and ride in PAS mode to see if sensorless mode kicks in. **
J
*I found out that the Sanyo hub I've been eyeballing is only a single stage reduction so an RC motor would not even be close to being feasible.
**At the moment, I have my motors disassembled for some wild ideas I had two weeks back, soon TBA!
