You might try checking with Rick Roller at Transmagnetics. He make some custom rotors for motors he built. Transmag rotors look like that too, but I don't know if they would fit.
fechter said:On the Honda Civic and Insight hybrid motors, there is a band that goes around the outside of the magnets. A band could be made of thin stainless steel or made from Kevlar or carbon fiber. You could DIY a Kevlar band by using thin Kevlar thread soaked in epoxy and carefully wrapped around the rotor.
lepton said:The rotors on the BMC non-hub motors are completely smooth, with the magnets inside. I'm not sure what material is used to get that surface finish, but its almost like the magnets are completely covered in an epoxy, making the entire face a continuous cylindrical wall. Something like that might allow for a smaller gap, and you could use regular rectangular magnets.The magnets don't have to be physically exposed to be magnetically exposed...
I'll try to take a closer look at it when I get home.
fechter said:The magnets on a BMC motor are actually one solid ring of magnet material that has been magnetized with 8 pole pairs. They are not separate magnets
Papa said:http://www.evalbum.com/876
fechter said:You might try checking with Rick Roller at Transmagnetics.
frodus said:Papa said:http://www.evalbum.com/876
Its currently in our shop
We just replaced 2 batteries (after 3 years). The thing is CRAZY fast... I've never gone full throttle. It'l do a burnout. We broke 2 front wheels doing doughnuts around the shop. Its pretty neat.... 2 AC controllers, hooked to 2 alternators (we just broke the windings out so there were 3 phases, and ran them out to the controller). The alternators have slip rings and a field coil in the armature (it doesn't commutate). The AC controller has 3 phases and an extra output to "excite" the field on the armature. Fully programmable, regen, 150A per phase, 60V.
If there's enough interest, we'll start making them again.
Link said:Curses. Even my oh-so-gangster knowledge of etymological structure isn't enough to think of anything better than "altemotor". :?
And I guess that Randy got banned because he was a bunghole. I wasn't around then, so I can't really say how big of a bunghole he was.
frodus said:what RC thread?
And when you say Kv, what do you mean? Volts per RPM? Its AC, you make it go as fast as the motor will handle. I'm not exactly sure what you mean bu adjustable Kv.... if you mean variable frequency, then yes, its variable frequency, so you can control speed.
Efficiency is VERY high, we've calculated it on the larger ones to be around 97% I will ask about the EFF on the AC, its going to be pretty close to the same, since we use the same controls for it, just different voltage/current FET's.
Yes, I'm sorry Kv as rpm per volt. It's mostly huff and puff, but there is some fairly technical discussion mixed in where Johnrob linked us http://www.rcgroups.com/forums/showthread.php?t=905411
To me good efficiency combined with the ability to vary the Kv has the makings of a perfect motor for our purposes unless I'm getting something wrong. If you can have a low Kv that increases torque that is used for take-off and hills, and then a higher rpm/volt for higher speeds, then your motor can run in an efficient range under greatly varying conditions. It can eliminate the need for variable gearing as well. To me it's the biggest knock against hub motors, because their fixed gearing makes them so wasteful at low rpms. Not only does it waste battery power in the slow range, but that inefficiency directly causes problems with heat.
lawsonuw said:...Field weakening doesn't give a motor more torque. It WILL allow a motor to produce significant power at 2 or more times the maximum speed at full field and a fixed input voltage. Nothing is free though, field weakening also reduces the efficiency and power output of a motor. Field weakening is most useful for an E-bike because it will allow a motor to be geared for good low speed performance. (say 15mph max at full field) While allowing an E-bike to reach much higher speeds. (say 30-40mph limited by wind resistance and motor power output of course)
Marty
John in CR said:Does "good low speed performance" mean good efficiency while providing high torque at low speeds?
John in CR said:If so then how much efficiency is lost as the field is weakened for higher speeds? Might this kind of alignment make a lot of sense in terms of overall efficiency for someone with a lot of stop and go and/or hill climbs in their typical route, while having a great top end for the flats at reasonable efficiency. In terms of being able to dissipate heat, some sacrifice of efficiency at high speed may be worth it if there's a gain in efficiency under heavy load at lower speeds.
John
lawsonuw said:John in CR said:Does "good low speed performance" mean good efficiency while providing high torque at low speeds?
Yep. Assuming the bike is not speed limited by air drag and the field can be weakened to half it's peak value, a bike would be able to use a gear reduction of about double what it would have with no field weakening.
John
Let's assume the field is running at half of its full current. The motor now can spin twice as fast, has half the torque per amp, but the armature still has the same resistance. Hm... time for some equations. The equations in the attached picture are for DC motors, they still apply to an alternator conversion if a box is drawn around the controller/stator and the controller is locked at 100% throttle. For now we can ignore the Inductance term, it is only significant during rapid changes in input voltage. (aka during PWM) "Wm" is the rpm of the motor expressed in [radians/second] "Tdev" is in [Newton*Meters] With a bit of algebra it can be shown that the motor's power output is ideally unaffected by weakening the field. (i.e. a reduction in "if") The loss in efficiency comes in because a lot of parasitic losses of the motor are proportional to the rpm. (or the rpm^2) Also, for a given torque output more current is needed with a weakened field so I^2*R losses go up. In an ideal world basically a 1000w motor at full field is still a 1000w motor at half field, the motor just spins 2x faster. In the real world spinning 2x faster causes parasitic losses to go up a LOT and this can kill efficiency.
I hope that was clear?
Marty
I don't know nothing about nothing when it comes to this stuff but I'm reading and learning. I'm an auto mechanic and sorta get it but to get to the point what about the glue Chevy used on thir trucks from 1988 and on to hold the door hinges to the body ??? That stuff works darn good !! Never saw 1 come loose ! Just a thought, trying to help...POPSfechter said:johnrobholmes said:It will be a while before I get to the project. I may have another company make the rotor for me, as my expertise is not quite enough to make a high quality one. I would want the magnets held in a frame and not just glued on.
You could use a slot that went over the edges of the magnets a bit, but this would shunt part of the magnetic field unless it was nonmagnetic stainless or something. Ideally you'd want something resembling a dovetail so about half the magnet sticks out above the rotor core. Finding magnets like this would be nearly impossible and grinding them is equally difficult.
You still need really good glue too. Something that won't fall apart at high temperatures.
