harrisonpatm
- Joined
- Aug 8, 2022
- Messages
- 846
I have a 24s LFP battery on my e-motorcycle. I use a 12vdc converter to power accessories (headlights, signal, horn, phone charger). I started with a model similar to this; not exact model, just this style. I got one with a 10 or 15A rated output, cant remember which, I just knew that I only needed about 5-8 amps of DC for headlights and whatnot, so I picked one overrated for my use. After about 6 months of use, it had suddenly failed, not sure the cause. The failure symptom that I found with my multimeter was that the wires for the 72v input were shorted, read as 0 ohms resistance. Luckily I had fused the input with a 2A fast blow glass fuse, so the battery itself didn't short, and even if I didn't fuse the input, my BMS is rated against short circuit (not something I want to test).
My guess at the time was because that style of converter is just a board in an aluminum case, not weather or vibration proof. No big deal, I replaced it with one of these, the 10amp version (exactly model i used this time). Went with that style because it's all potted, so I figured I'd be good against weather and wear and tear this time. Cut to yesterday, and it failed again, except this time I was paying attention and I think I found the cause:
I had just finished charging my battery to 100%, recently. I pulled out of the driveway, went down a few houses, and let my regen stop me at the stopsign. I felt regen for a half second, then cut out. When I checked the log, sure enough, the BMS recorded an overvoltage protection. That first burst of regen on a mostly full cell had briefly pushed it into overvoltage territory, so it had disabled charging to the battery. Since the battery wasn't allowing charging, and the controller was still on, it attempted to "charge" the only thing directly connected to the battery, which was the converter. So the overcurrent fried the 72v input, and on this second failure, I checked the same symptom, which is that the input wires read as a dead short.
I've tweaked my BMS settings a bit to hopefully prevent this from happening again, and I could also lower my charging voltage by a bit as well, giving my battery more headroom for that first regen current. However, what i'd like to know is, why did this happen twice, even though the 72v input is fused? This is specifically why I used a fast-blow 2A glass fuse, rather than something like one of those inline auto fuses, because I was trying to protect my converter from sudden overcurrent. Except now it seems like overcurrent is getting past the fuse, to the DC converter, frying it, causing an input short, which then blows the 2A fuse. How can I change this so that the fuse blows before the converter?
Or am I wrong about the reason why the converter has failed twice?
