harrisonpatm
- Joined
- Aug 8, 2022
- Messages
- 847
Wanted to ask this question separately from my build thread in case it's easier to see.
I currently charge my 72v nominal motorcycle from my 14s Li-Ion DIY powerwall, using a boost converter. Input is my home powerwall, I set output to 83.6V, and it works as a CC/CV power supply. Works great, I get a solar-powered motorcycle, and efficient thanks to no DC-AC-DC conversion.
For my upcoming build of 28s Li-Ion, I would like to implement a similar system. Trouble is, it's harder to find off-the-shelf affordable components that are rated for over 100VDC. Currently I use this, but it only goes up to 96V. So far I think my best bet is this that I found on amazon. Goes up to 120v, but only 900w. I don't mind charging slowly, it's better for the battery anyway, but I'd rather stay well under the max rating anyway (say 600W?), and that might be too slow for a 9.5kwh battery. So I could purchase 2-3, and parallel their outputs. That's my best idea so far, but it'd be bulky and might be overcomplicated. Plus there will be conversion losses for each component, I'd rather just have one single component.
I wanted to check the forum first, has anybody seen a 1kw+ rated boost converter that can go up to 120V? Thanks in advance.
