mistercrash
I was sure there was a thread about that but I couldn't find it.
I have a 16S20P battery made from Makita 18650 cells. I charge it to 64V and don't let the voltage drop below 56V. I tested that this gives me 23Ah to work with. I have two speeds on my controller, low and high. I always use the low speed because the high one is too fast and I don't want to burn up the motor. I run a heavy scooter and I'm a heavy guy. On 16S the low speed is barely 30 km/h. I'm wanting closer to 35 km/h.
Go see this please: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16226
Can I get three of these in parallel and connect them to my 18650 battery in series to get 20S? I would charge to 80V and not discharge below 70V.
Will these HK lipos help with voltage sag a bit?
Is this a good idea?
Thanks
Ray
Thanks
Ray
