Yes it is the perceived risk that keeps more people from using them. I have made a battery bunker for my Lipo's. and charge outside and charge at about 1 c rate to about 1.2 c rate .
Are you using the 750 watt or the 1,000 watt HP Server Power Supplies ?
Can you post some pictures of how you modified them ? Close up of your solder areas that you soldered on the Board .
No you are not missing anything from not using 18650's, I have stopped using them except for inside my little scooter, and even thinking about using lipo's on that when the 36 volt 18650 pack in it now no longer gives me much range .
Although when I do finally get a mid-drive so that I can go on the trails/up hills and mountains, I Will be building a box for those lipo's .
When I do finally go back to using round cells I will be looking at 21700 cells. ( the same as the newer Tesla's ) but bought from somewhere else as Tesla does not sell just batteries. Waiting for them or another size to be larger mAh per cell than what is available now .
I am still trying to figure out how to balance charge a round cell battery pack, should I decide to make one in the future , since with them there is usually 4 or 5 in Parallel, where as the lipo's have the advantage of being 5000 mAh each cell/pouch or even more, so there is only 1 balance wire per cell in the pack, in other words they are 1 P packs.
Now that I use Hobby Chargers that have the balance feature, I prefer to charge that way . I can see the state of charge for each cell,
whereas with a retail bought 18650 cell pack , I do not see the state of each cell and have to put all trust in a BMS. That sometimes fail and burns houses down . One ES member said that when he built 18650 packs 2 out of 5 had BMS's that did not function properly.
With a good Hobby Lipo charger that problem does not exist.
And if someone is not good at looking at the display to see how much your Hobby Lipo pouches are draining down to during your ride ... just plug a small lipo checker into your balance wire connector and set the alarm to sound when any cell goes down to the voltage you set it at , like 3.65 or 3.75 , etc .
Joecool said:
Is it the risk associated with lipos that cause others not to use them?
I also use a 1000W 8S 40A Rc lipo Balance charger coupled with 2 HP 12V server power supplies that I modified to get 24V DC to the charger.
Ive been using that to balance charge all lipos, SLAS, etc for 5 or so years. Am I missing something from not using 18650, Teslas 2720, or EV leaf battery packs?
