hi guys i need a 48v charger can i use 2 24v wired together to achieve 48v ?
O okmate 10 W Joined May 3, 2012 Messages 65 Jun 5, 2012 #1 hi guys i need a 48v charger can i use 2 24v wired together to achieve 48v ?
Drunkskunk 100 GW Joined Apr 14, 2007 Messages 7,244 Location Dallas, Texas. U.S.A. Jun 5, 2012 #2 No. But maybe Yes. 2 24v SLA chargers that don't reference the same ground could be wired in series for 48 volts with no trouble. not all chargers work the same. If your charger is a CC/CV type with no common ground, then it will work fine.
N nechaus 100 kW Joined Oct 11, 2011 Messages 1,876 Location Brisbane > AUSTRALIA Jun 7, 2012 #3 you know you can buy 48 volt chargers for less than $50
