karma
what you need is lots of sleep :wink:
amberwolf said:Oddly enough, even with the long hard accel on that straight, plus as much more hard fast riding as I dared, I still only had 26Wh/mile when I got home. I really expected it to be much worse than that.
amberwolf said:I still need to try a longer stretch of preferably non-public road to see how fast I can get and how long it really takes. But gotta do something about the brakes first, so I can stop quick in case of bad stuff.
I fully expect that if I were to ride at the 25-30MPH all the time, I'd have significantly higher Wh/mile. I'll see for sure about that at the Death Race if I can make it, as I will be able to ride as fast as I can control the bike on turns, and hopefully increase the startup torque to get faster acceleration out of curves and from a stop (20+ seconds from zero to 28MPH is terrible).miuan said:I've had the same experience so far. Riding @ 35-40kph range, my bike didn't consume too much more juice than @ 25-30. Sure you produce more aero drag going faster, but you have more switching losses at low speeds and the motor is less effective. Going past 40kph up to 60kph, the Wh/km consumption doubles on my rig.
Someone on ES once offered to buy some good Shimano levers and arms/pads for me but never got around to it. It doesnt' really matter because I've got the main stuff I need for disc brakes (a few sets of calipers, both new and used, and several sizes of rotors) except the mounts on the fork (or rear frame) itself for the calipers, and a mounting point on the 9C in front or the regular hub in the rear. So it mostly comes down to time to do the work, and tools and knowledge to do it right (or experimentation). TIme is the biggest problem.It would kinda defeat the "recycled" nature of the bike, however I do recommend a good set of brakes, especially if you can't get a disc mount.
I think my main problem is that my lever doesn't really match the arms being used, as the lever is from a Honda scooter (part of the switch cluster and mirror mount), but the arms are from a Shimano system (I forget which one). What I need to do to make them really effective is to eliminate the Honda lever, and use a complete matched set off of one of my better bike finds, like the Nishiki (which has some pretty good Shimano stuff, cant' remember which series though). Or even the ones off the rear of a Mongoose I got at a thrift store for it's front disc stuff--it's rear vbrakes would actually do a good job of locking up the rear wheel on that bike during the little testing I did of it as a bike when I first picked it up.To my great surprise, I found my V-brakes to be very effective in pretty much any situation, even at high speeds and cold/wet.
amberwolf said:as the dogs only have about 4 days left of it or so.
I really appreciate it! But...I'm not sure exactly what I need, or rather, the list of what I "need" is so long I couldn't really type it up. :lol: It's typically easier for me to figure out how to use something else for what I want than it is to figure out what the *right* thing to use for it is, and name it.karma said:hay i have 4 Tupperware containers full of parts you could use. send me a list of what you need if i have em there free.
only thing not free is the shippin :wink:
Didn't I post about that? I thought I did, but I might've forgotten. Can't find the post now, or a PM for it.never bothered to ask. did you get the controller? is it working?
