contador
Hi,I have a headway pack 36v-10ah LiFepo4 pack,unused and stored for six months or so charged a couple times during storage period.
Fresh from the charger it shows 43,5 volts,but drops dramatically to 40/40,9 when pluged to the controller and when the throttle is pulled before riding.
When riding, the voltaje drops even faster and the power is cut at 35,5 volts in less than one km.
The sistem is a 350w Nine C,22A controller.
Hope the problem is the charger.(2 amp).When charging the green light turns on in a bout 10/15 minutes ...so I dont know wht to think.
Measuring the voltaje of the series its going to be a hard task because the BMS pins are completely glued,so first i need to make sure the charger is working right ,how do I check that?
Thanks in advance
Santi
Thanks in advance
Santi
