docrocket
1 W
- Joined
- Apr 12, 2018
- Messages
- 52
So I finally finished assembling my 13S3P SPIM08 battery pack monstrosity. This is a straight-up experimental build and I suspect I'm going to have reconnect everything after a test ride or three.
Unfortunately the 48v charger I bought with the rest of the bucket of parts was DOA. So I have a constructed battery pack with basically a full charge (52.6V) but no charger. Ordered a new one, it'll be here Monday night.
I'm going to be running this battery with an old no-name 36v controller - it's confirmed as having the voltage capacity to run 48v. The battery has a 13S BMS installed.
I'd like to take it for a range test. I also don't want to have to keep swapping in and out the 36v menagerie I've been powering this bike with. I know that charging a 36v on a 48v charger is Very Bad Mojo. But it seems like it should be OK to do the the other way around - it'll just give them a partial charge to around 3.5 volts/cell. Which is fine; the SPIM08s can go to to 2.5 volts before the cutoff.
I also have a SkyRC B6ACv2 hobby charger (which is how the cells got charged to begin with). Can I use that to somehow charge the whole pack or do I have to tediously disassemble-reassemble?
Main question: is it safe/non-damaging to charge my 48v pack at 36v for a few days while we wait for a proper charger? Thanks.
