HAL9000v2.0
[micro-kilo drive]
Here is my version on small bike drive. I have been working on this allmost a year now and this combination of motor/controler/f....ng-EU-rules works the best.
It has 958 grams w/o batteries and up to 800W works fine. For bigger power it needs different rolling surface and maybe support bearing. This one acualy made 500km on training rollers with constant power output (on roller) between 720-775W with thermal equilibrium at 36°C with room temperature of 22°C. The drive can work constantly at 1kw up to room temperature of 42°C. After that controller thermal protection shuts down the controller. I think it is at some 85°C.
I have tryed all sort of engagement mechanisms and finaly I have decided to go with hand operated lever. The pressure will be controlled with 2 springs. Also I have to install current limiter but first I have to measure efficienci corectly. I want to have 249,99 W on the wheel. For now I have some 57% and I found out that it is proportional with roller pressure. The best way will be to make some adjustable pressure device...
Here are some pictures...
