Wish you are speedy recovery and well I could have predicted the back pack will not be a long term thing for most people. Even if it wasn't the cause it sure doesn't help carrying a few kg on your back or possibly have some distant effect in exerting your stomach muscles. Raptor 140 could be good to?
I seriously need two good bikes on the go. Part of me says just buy a dam ebike frame. The other says bending a piece of aluminium is not that hard at all. Side covers out of plastic are no big deal either. Now if you are going to serious jumping and stuff then a proper box would be better for battery protection I guess. For me I like the open design, it's easy to work on things and charge up.
Build "progress"
I cut into the rubber centre part of the motorbike pulley, which was raised up in the middle to hold the motorbike chain better but was shifting my chain left or right depending on where it bounced to. This was making the chain feed poorly on the 48t sprocket and then derail and jam.
It would seem without riding it up the mountain really rough that the tensioner is working ok for now. The bracket does rub against the chain, but once under more tension it is straight with no rub. so quite little rub because of my body weight "presag". the final working is 30/48 teeth with a 10 speed chain. Really sad about the 7 speed chain because don't know how long this will last. Anyway she is really slow at a ratio of
1x1.6
It has been raining for ages. I tried going up to my super steep testing ground a few times this week but the mud is thick and impossible. I am really hanging to see if this new ratio can pull through the super steep sections alone. AT the 40-48 0r 1 x 1.2 the bafang couldn't.
Edit 1: trialled on my driveway hitting a bump on full throttle uphillish: no problems
[youtube]DQAMQLQdF-w[/youtube]
Edit 2: Did an off road test ride and the chain stayed in place. I am still worried because I didn't do a full compression anywhere. I am a bit worried that the tension might destroy the chain.... Oh well with time Ill find out.
I just recorded the corner which I failed on in the past.
Actually rode up 3 times. twice only bafang and once it ran out of juice right out the top and the other lost traction. So then I went dual motor and made it through.
On the other sections there is no doubt the gearing difference between 44/48 and 30/48 is huge. I almost made it to the top of my mountain killer and found the hub was struggling to help at 12s....
both motors are matched in their ability at the crawl but it is obvious the mid drive does better at granny for efficency.
[youtube]A2z1tCqbw6g[/youtube]
Edit: I just keep going up testing the chain but nothing is moving? I really need to do some bigger drops...
[youtube]XK6tTT-qyDc[/youtube]
Edit 4:
Did my usual circuit with a bit more stuff on the side but I did it in the opposite direction, which I call the hard way, as the climb up the mountain is much less fogiving. I am trully happy with the tensioner now. I am sure it is perfect for the job...
Now there are lots of things to say about this ride.
One I went up some parts I never have before just with the bafang. A bit of pedalling and a bit of leaning. Was stoked!
However there were a few spots where the bafang either ran out of power or lost traction.
Lastly, at 12s 60a just when the bafang is struggling the hub motor can't help at all, and not only that the voltage sag increases and it almost feels worse to use both at the same time. I'm not sure about the voltage sag yet.
So I'm kind of thinking painfully that 12s is not enough (or currently roughly 44v x 60A = about 2.5kw) and hope that maybe 15s with greentime controller roughly 55v x 80A = 4.5kw.
I love the weight and look and balance and charging and even being able to hold full throttle through rough riding of the bike at 12s3p... But I really think
I need to go up by another couple of kw to power through a few points and out run some traffic.
the 3s turnigy 5.8ah I already have are not listed in au. or int. anymore! dam it...
