Lots of trike pics, it is now rideable under power but no chain yet. still working on chainline. Any suggestions welcome.
I had a miscalculation about the width of the trike. I was SURE I ahd measured the front door as 36" actual usable width including the space the door itself takes up against the wall, the jamb, etc, but apparently I scrwed that up, and it's probaly closer to 33", if that, cuz the trike don't fit thru it.
It's at least two inches wider than the doorway's available usable space, and even if I cut the axle ends off flush wht the frame on both sides (impossible) it still wouldnt' fit htru. I am SURE I checked this before, but obviously I dreamed it, or else the house shrank.
Anyway, so I have to shimmy the trike around the doorjamb at the knob side, kinda like you would to get a couch in or out that's too wide for the doorway, where you feed an arm out at an angle first, keeping it all tilted as you go thru with the middle, and then back at an angle to get the other arm out. With the trike, I have to turn it almost sideways to the door, sort of lift and drag the riht wheel over the doorsill, whcih I can barely do because I have ot do it from inside the house from the left side of the trike. Then scoot teh trike sideways and sort of back and forth until the back end is out the door, then roll it backwards to get the front end out. Same thing in reverse to get it insde, and it's even harder because I have to lift that rigth wheel up farther to get it over the doorsill from the outside direction.
Oh, the best part: I have to take the seat bottom off to do it at all.
Meaning, take the seat bottom off, get the trike out the door, put it back on, ride, come back, take the seat bottom off, get the trike in the door, etc. I just wont' be putting the seat bottom on except when I'm outside with it to ride. Maybe see if I can come up with a quickrelease for it, instead of four allen-head bolts.
I seriously considered narrowing the trike by cutting some of the right side frame and "axle" section of the kit away, about four inches, on the left side of the rigth wheel "cage". That woudl let me easily roll the thing in and out the doorway, but it would also make it much more prone to tipping, and also make it very non-symmetrical. So i left it alone and for the moment I will deal with the shuffle method, but I'm not sure that I *can* do that when I'm hurting enough to have to use the trike in the first place.
So...am also considering making it collapsible on that side, with al lthe tubing having a "telescoping" section that slides over the rest, and then nuts welded on teh outer tubing with butterfly-head bolts or t-handles or something thru the nuts and a hole int eh tube into the inner tubing, to lock it in place when extended. That's a lot of work, and may not even do what I need it to, but it might have to get done.
Ok, bakc to the how-to stuff:
Extending the steerer tube: First I made sure all the headtube/bearing/etc hardware was setup like I watned (cuz I can't replace it after I do this!).
Then I took this old seatpost and cut off the wider part and the "flange",
leaving this part to be slit and hammered into the steerer tube off a junk shock fork
which even though ti's only 16" wheel sze still weighs as much as a jug of water and has almost no springiness at all.
but it wroked out fine, fits like a glove and extens the steerer tube safely
whcih I then welded thru the tubing on a high-amp welder setting to cause burn-thru on purpose, and then ground down to flat so the sterer extension for the bars to clamp to will slide over it.
Seat base attachment:
Next up I cut the seat bse of f the chair stand, and ground it flat for weldign to the bmx frame
so ti sits like this now (beofre weldign by stpot weldign the four courners of it to the stays):
Actually doign the welding was a huge PITA because I couldnt' find a way to clamp it without the clmaps slipping on teh tube, and I tired wood and other stuff across the top and bottom but even that kept slipping just as I'd get it tight. Must've wasted 45 minutse on taht, and eventually juet held it with one gloved hand while tacking it down on one side, forcing against the tacks to do it on the other side, checkig my work and cutting it off and retacking it a few times before I got it stragith enough, and then really welding it. That sucked.
I put the handlebars on the tube and clamped it all down, using a stem from Oatnet called "black mrkt" I think it is. Seems to be steel not alloy, and is VERY short--ideal cuz I don't need leverage on this thing much, and don't want to hae the bars far foward or back from the steerer tube. Found the right height spot for them for arm comfort, about teh same place I hav them on CrazyBike2 but their a little closer tahn CB2's; feels beter. Forgot a pic but you see them in others later.
Then I went for welding the pedal boom on. Old seatpost fishmouthed at the former seat end, then again just held in place whiel tacking it. miractulously this actually worked perfectly the first time. My welding still sucks though cuz I cant' keep my hands steady OR on course and drift away from the seam area.
PEdal boom itself: I put it on there adn sat in teh seat, and found i neede d to take at least two inches off teh boom to reach pedals prperly. Easy to do; just cut clamp ring off, cut a couple nches off boom, slit it for like 3 inches and put clamp ring over it. Slide it over boompost, and clamp it down. boompost narrows for last couple inches, so I actually gained 4 inches of adjustment range this way (towar d the short side--already has plenty of adjustement the other way). Ended up what feesll ike a perfect fit.
So at thsi point the trike is like this:
and I remembered to finally put a tire on the elft side (so now it ahs the Armadillos from Ohzee on each rear wheel; hopeflly will keep me from getting flats on it...Oh, and I forgot to ever metnion it, but the front wheel is actualy a rear wheel with most of the spacers/nuts off, and crammed into teh dropouts of the fork, and it is a solid foam tire, so it can't go flat. It's th e wheel that was gonna be the front tire of of ReCycle. I think it is 44 spoke or 40 spoke). I also played with placments of the ammocan battery it will start out with. The first one I realized was stupid only after taking the pic--the chain has to go thru there. Fred realised it before I did though, and tried to tell me....
This might work out, on the axle on one side, rooom for two packs taht way. Or a pcakc and a toolbox, or whatever. Probalby ought to sling it UNDER thae axle instead though, and drop all the cargo racks down to axle level.
I played with chainline possibilities, but realized that i just didn't have time to do that part today, after I woke up from yet another unintentional nap when Nana came up and pushed me over to say hi, and I saw the sun going behind the big tree and shading me. I forget what time that was, like 4pm or later, but it meant it was time to start cleaning up out there and bringing stuff in (takes an hour or more) before it started cooling off too much, so i could clse up the house and not lose all the heat gathered from airing it out during the warm part of the day.
So up next was in-the-house work, of wiring up the Fusin kit and lights on the trike (cuz they're all one big wiring harness just ttransfered voer from the Fusin Test Bike that hte kit spent it's first 500+ miles on, successfully. I intended to tkae pics of each step of this part, too, but I kept forgetting to do it, or I'd go get the camera nad forget what I was gonna do next, so at some point I just stopped trying and only got pics of basically finished (except pedal drivetrain) trike.
I guess i got my fingers nt eh way of the flash or somethign:
Somwhere in here, Loki gave up on me and didnt'e ven wake up when i dropped things noisily, which is very unsual for him (he's the scaredy-dog of the group, afraid of everything).
Bike reflectors at the ends of the back of the top cargo tray, and the motorcycle tailight (with "license plate light" shining down on an endless-sphere bumper sticker from Mr.Electric). The fusin kit's taillight is ziptied to the top of the seat back, partly cuz it is a white light with red lens, so if I need to see the cargo area when loading or unlaoding or whatever, I can pop the cover off and use it kinda like a flashlight. The turn signals ae under the kit's rear crosmember, ziptied to the lowre cargo tray. Ammocan pack is strapped down to the lower cargo tray in the front right, for now, so I can test this thing.
then with the lights on (are off in above pic), left turn signal going. Has the flash on the camera too, meant ot block it but forgot.
I did block the flash on the pic of the front with the lights on. The car headlight is ziptied to the top of a stem from Oatnet clamped to the steerer about 8-10" below the handlebars; this keeps the headlight lower than my eyes by enough tht I can see shadows cast by it on stuff in the road, and thus more easily see what I must avoid. The fusin headlight is ziptid below the stem. I only even have it on there because it has the keysiwtch in it, and I just wanted to test drive this thing before doing any major rewiring. Turn signals/front markers are ziptied to the handlebars.
not nearly as messy looking as CrazyBike2 yet, but not doen. :lol: Lights are on and camera flash too.
outside view with flash and lights on.
same but no flash
EDITt: i dozed off so many times typing this up I think it took two hours to write.
must've click submit by mistake somewhere cuz I had to go back and edit in the last half of it or so. was afraied I'd lost it cuz for some dumb reason I typed it right into the edit box in the browser instead of in notepad first like I usually do.
But before you go, my usual grumpiness:
Weather was better, was able to do a lot in between involuntary naps, cuz i stil didn't get enough sleep; hardly any at all. Now that it's warmer and my bonz don't hurt quite so much, one of my toothaches came back with a vengeance (lower left molar I think). Ibuprofen took off the edge kinda like it does with my body aches, but still throbby. I had a couple of Darvocets left, and used one of them so I could at least get a little sleep. Am using another now so I can get hopefully enough rest for work tomororw. When those run out I still have a few Tylenlo3 with codeine left from a few years back when I had to have the front top two left teeth pulled (incisor and canine?) from an infetction cuz I broke them off when i tripped and fell due to complete exhaustion, when my mom was really sick in her last year, going to and from the hostpital lots and lots (felt like every other day), and I felt like the only person that was doing anything around the house (and I was the only one also holding a job; neither of the sisters then here did or has even now, that I know of). Anyway, I will get thru it, like i always do, eventually. Even if I don't like it.
end of rant
