Hyena
OK, so here's yet another example of lipo badness.
I was super lucky in this case, as below.
To take it from the top, someone sold a guy a conversion kit and large 18S 30ah lipo pack. The seller apparently bought a kit or parts from me many years ago and has tried to copy the battery construction with a whole bunch of hobbyking lipo. He then sold it for an absolute fortune to a noob, using my name, saying it was one of my kits. Not cool.
This is how I received the battery from the new owner. Not surprisingly, he's not sure about how to use or charge it, with the supplied 25v charger,3 celllogs and a battery medic...
This was made by a guy in Perth named David. David, if you're reading this you're an asshat and a jerk. But I digress
So what he's done is string all the discharge leads together in series and parallel, with the 2 bullets being the main 18S ~75v output.
Back in the day I used to parallel charge my lipo packs, so used a 6 pin anderson block which essentially isolated the sub packs when disconnected and put the packs into series for discharge and parallel charged at 6S voltage. This guy has partially copied that, with a 25v charger but hard wired all the cells into series. Thankfully the new owner didnt try to connect the charger. And lets not begin to think about how the guy was supposed to check, monitor and maintain balance with one BMS for all those individual, unparalleled balance taps!
OK so that's the back story, and in order for the new owner to try and salvage something from this pack I offered to re-wire it and fit a BMS so it was atleast somewhat save and plug and play friendly for him.
When I started to disassemble the rats nest of wiring though I discovered that a number of the cells were in bad shape, 6 of the packs were significantly swollen and reading ~4.25v /cell. The rest of the cells read betwen 3.8 and 3.5v.
So I removed the obviously bad packs and emailed the owner to see what he wants to do with the remaining cells. I'm not too confident in how well they'll go. I can potentially still make a 20ah pack from it but who knows what sort of capacity it'll actually deliver.
Oh yeah, the fire.
So I put the bad cells in a biscuit tin and put them outside my garage until I could dispose of them properly. For long term storage they should have been in something more sturdy but that's all I had on hand. They were sitting a few inches from my closed roller door and about 3 feet from the back of my car.
I went to work this morning on my moto and got a call around lunchtime from the inlaws having picked up my kid from preschool saying the house was full of smoke After a thorough check of the house and garage they could find nothing burnt until they walked outside.
The packs had spontaneously exploded (perhaps the hot sun heated up the tin they were in ?)
The damage is thankfully fairly minor, black bricks I can probably blast clear but the roller door is toast.
There's no sign of the neighbors but inspecting what's left of the packs there's water in the base of the tin and the hose is across my yard, not where I left it yesterday. So someone has seen the fire and tried to hose it out. While we know water on lithium fires isn't too effective I'd say this saved my house, and they probably don't even realise how/why.
I dont know if they were on sight quickly with the hose but I would have expected the damage to be much worst actually. This is 6x 5ah bricks worth - I've seen similar fire from an intentionally detonated single 5ah pack...
When I rolled up the door I found a bottle of oil just a few inches away from the inside of the door. As you can see the heat from the fire even through the door was enough to deform most of the bottle and melt a hole in the top. A few seconds longer and the hole would have melted lower to release 3+ litres of oil, which would have then spread across the floor and surely set the whole joint on fire.
Damn...
So, lessons learned ?
DON'T DELAY in disposing of your old lipo.
I'd like to think I'm a veteran when it comes to lipo and the only other incident I've had in the last 8+ years playing with the stuff was my own fault. I knew the rules, I knew this pack was a gonner and dangerous but it got the drop on me. Had I left it inside the garage instead of outside in the sun it probably wouldn't have blown up. Or maybe it would have anyway, and taken the whole house with it. I'm up for atleast $500-1000 for a new roller door but it could have been much much worse. But I won't REALLY pay until the wife gets home and sees it :lol:
Oh yeah, the fire.
Damn...
