gaisom
I am using an icharger 1010B+
I noticed on one pack when I went to charge it that cells 1 thru 7 were from 3.70 to 3.74
However, cell 8 showed at 4.10 and made me think it had not discharged, like it had a bad connection. The voltage for the whole pack reading was correct though. I checked the balance port using my Low voltage alarm and it shows that cell 8 is indeed at 4.10v
What could have caused this?
BTW, I am very dissappointed with the balance charging on the 1010 b+ I expected it to be very accurate. Instead I have variances of from .02 (3.98) to .05 (3.93) between the 8 cells in every pack, and none of them came up to the 4.10v that I have the charger set up to balance at. I rechecked the program and it was set on balance charge with an upper cut off of 4.10v
Any suggestions?
Any suggestions?
