Finally got the bike running and made a short trip (8km) in -15C weather. On the way back noticed that there was a problem to start the motor on the way back and keep it running. Got a really bad noise, almost like brakeing a gear - but believe that this was due to a loose motor phase wire connector. Anyway when doing a closer inspection noticed some wobbling between the hub and sprocket. Got really worried if my axle is bent ?
Anyone with more experience with rear hub motors, I would appreciate your feedback to the video below. You can see how the freewheel sprocket distance to hub motor is not stable - rather its moving all the time a couple of millimeters. I did have some problems in installig the freewheel pack, but dont understand how it could be that as the movement of the freewheel pack in relation to the hub motor is so slow.
[youtube]http://www.youtube.com/watch?v=UHiPlh2XOTQ[/youtube]
Btw - in Xie Chang programming software there is a bug, it will loose information if 120% speed is used. And the Xie-Chang controller with Bafang confirms the rule: Blue stays, Green and Yellow needs to be changed both as sensor and motor wires. As stock the Xie-Chang controller comes without sensor jumper wire configured. That took some time for me to figure out that it needs to be added to the PCB. The autopilot for speed is handy, but unfortunately only works with throttle - not with pedelec sensor, so it kind of locks the hal throttle signal to a position and keeps until brake lever is depressed or throttle is adjusted. Very handy controller with a lot of versatility.
The bike itself is otherwise nothing special, a kona with banfanfg, 36V10Ah battery and Xie-Chang programmable controller.
